Hi Dennis,
Not really, but the process should be fairly simple. First adjust the InputGain0 so your Encoder Resolution becomes the same as your MicroStep Resolution. Make Step Response Moves to verify that the commanded and measured positions match (with small errors). Then switch the Output Mode from "Step Dir" to "CL Step". Set the PID gains to all zero so no corrections will be made. Set the Max Following Error to the value you would like to cause a Disable and Stop.
